Does removing AIR set off the SES light?
Re: Does removing AIR set off the SES light?
Yes. I believe you can put some o2 sims on your back o2 sensors to fix the problem. I have some for sale cheap. My car has been programmed to where I don't need them anymore. I only used them for a few months.
Mark
Mark
Mark
Mark
Originally Posted by )2overt SS
Back O2 sims? Why? I'm confused... my AIR is not pumping air into my exhaust and my back O2 sensors are fine. I don't have an SES light on.
Mark
AIR cleans your exhaust by running it through your engine a 2nd time. The back o2 sensors measure your emissions. I figure removing the pump will cause your emissions to increase. Thus, setting off your SES light from your back o2 sensors. Maybe I'm wrong? Anybody else chime in.
Mark
Mark
In the earlier OBD-I cars, there is no flow detection, and the PCM only checks the circuit to the AIR pump relay, so you can unplug the pump, with no SES light as long as there is a good fuse in the relay circuit. But OBD-II is more complex.
Thanks, Injuneer.
I know when I removed my AIR, it set off my SES light after a while. I purchased the o2 sims and it fixed it. I figured it was the o2 sensors. I guess not.
Mark
Mark
Originally Posted by Injuneer
You're off base. The AIR pump only runs for about 2-3 minutes at startup to help the cats heat up to operating temperature faster. The O2 sensors aren't even hot enough to work at that point, so there is no way they could be tied into a diagnostic routine. The OBD-II PCM can sense whether the AIR pump is still in the circuit, and there is a flow detection device. You need to have the AIR SES light "programmed out" in OBD-II.
I thought it might set off the SES being unplugged.
Thanks!
Originally Posted by RamAir95TA
As long as there is a good fuse in the AIR system, the SES will stay off.
Gtpguy
01-26-2015 04:50 PM
95chwagon
01-13-2015 09:19 PM
sleeperZ96BT
06-05-2005 09:33 PM
