DONE with the LT1.
Old 10-17-2007, 11:07 AM
  #61
95z28 -quicksilver's Avatar
Location: Austin, TX or Texas State University at San Marcos
Originally Posted by Jditlfm
What kind of wire are on it? Also yes why didn't you have it put on a scope? I went through 4-5 sets of spark plug wires and many other parts trying to find my high rpm miss. Ended up being the wires from autozone and advanced tried all the different brands they had and they all messed up. I went with Taylor OTVC wires and Ac delco plugs, bam pulled like a freight train again. Thing is all of those wires appeared fine and showed normal resistence with a multi meter.
It did it with the Taylor wires and the MSD wires so I doubt that is the problem. Also had spark plugs changed twice.
95z28 -quicksilver is offline
Old 10-24-2007, 02:00 AM
  #62
edman's Avatar
Was harmonic balancer checked?
As you may have read in a chevy mag , they had an LT1 with a missfire that they dramatically changed out with aftermarket ignition bits also. They even went with an eight coil conversion and still kept the missfire. Ultimately, a marginally loose (or cocked) balancer with some stripped threads somehow caused their cronic missfire. Once the balancer was properly secured with new bolts , the missfire disappeared. There was no explanation given as to how this could and did cause a perenial missfire. Maybe pulling yours for a check is worth the effort.
edman is offline
Old 10-24-2007, 05:42 AM
  #63
Thats a good idea and i do remember reading something about that. However its too late, the engine is sold and I have a shiny new '01 vette motor in its place
Old 10-24-2007, 08:41 AM
  #64
David94TA's Avatar
Make notes on your swap, if you would and keep us up to date.
David94TA is offline
Old 10-24-2007, 11:03 AM
  #65
KyleBlue85Iroc-Z's Avatar
It's already gone! Wow! You weren't playing.
KyleBlue85Iroc-Z is offline
Old 10-24-2007, 05:23 PM
  #66
Haha yep, just sold the tranny and engine for 1000 and 3000 respectively. Bought a 01 LS1 out of a friends vette that did a LS7 swap, now i'm starting down that lonnnnng road that is the LS1 swap. I'll keep ya'll up to date, should be finished by christmas, my little Christmas present to myself
Old 10-24-2007, 06:13 PM
  #67
dangalla's Avatar
good luck with it, you deserve it after all this
dangalla is offline
Old 10-24-2007, 07:44 PM
  #68
Thanks, i appreciate it. I loved the LT1 but it never loved me back!! lol Just found a K member and maybe a transmission A couple steps closer.
Old 10-24-2007, 10:04 PM
  #69
1995blackttopta's Avatar
i hope you dont just throw parts at the ls1 like you did the lt1, it does not matter what motor it is, replacing parts will always come back to get you, you could have saved a ton of money by actually diagnosing your problem rather then just replacing everything between the fenders until it stopped(or in your case you stopped)
+1
as stupid as i felt paying $100 bux to find out my rough idle/not wanting to start after it sat/failing emissions turned out to be a hole in the intake elbow.... i had a new one on there in a few days and spent $236 total for the diag, the new aluminum hose, and a front main seal.... i can only imagine how much i would have spent just throwing parts.... i had thought it was the fuel pump myself....
1995blackttopta is offline
Old 10-24-2007, 10:14 PM
  #70
SS RRR's Avatar
It's too bad it wasn't put on an oscilloscope to see if the miss was ignition related...
SS RRR is offline
Old 04-17-2008, 10:24 PM
  #71
stephenspann27's Avatar
Coil Packs
yea I was going to ask why you hadn't tired a LTCC kit..
stephenspann27 is offline
Old 04-17-2008, 10:28 PM
  #72
TAEnvy's Avatar
I love my LT1 and I wouldnt have it any other way.
TAEnvy is offline
Old 04-18-2008, 12:41 AM
  #73
Dave1980's Avatar
Originally Posted by clcam97
did you clean your throttle plate?
Yeah and while your at it put a few cranks on the flux capacitor.
Dave1980 is offline
Old 04-18-2008, 07:03 AM
  #74
2000GTP's Avatar
Any update on the LS1 install?
2000GTP is offline
Old 04-18-2008, 01:48 PM
  #75
David94TA's Avatar
I was wondering about that also.
Quick Reply: DONE with the LT1.
