Double Diamond VS. Tubular Subframe Connectors HELP!!!
Old 12-10-2003, 10:41 AM
  #31
stereomandan's Avatar
I weighed my BMR tubular subframe connectors at 17 pounds for the pair.
Dan
stereomandan is offline
Old 12-10-2003, 10:45 AM
  #32
Red96Lt1's Avatar
Dan
Thanks! I'm guessing the boxed wouldn't be too much more than that. That gives me a good idea.
Red96Lt1 is offline
Old 12-10-2003, 11:02 AM
  #33
Gripenfelter's Avatar
If you are considering SFCs then you're doing them for one of two reasons:
1) You have so much torque that your car twists at WOT. (My case)
2) You're looking for better handling.
IMO, the price difference between tubular and double diamond isn't really that much. The fact that double diamond SFCs do a better job of #1 and #2 should be the only factor you should consider.
If you're going to do SFCs, take the double diamonds.
That being said, Sybersport has the best deal on them. info@sybersport.com
Tell Darren Grip sent you. I think they're something like $180 including shipping.
Gripenfelter is offline
Old 12-10-2003, 11:36 AM
  #34
transamtom's Avatar
I have the SLP DD connectors since about 15,000 miles(100,000now) and I am very happy with them.
I have had the car up on 4 jack stands a couple of times and I can tell you I really only needed 2
The car is so stiff the the other 2 stands were only sitting under the car not touching anything
The only thing I regret is not buying the powdercoated bolt ons and grinding the paint off to weld them.
transamtom is offline
Old 12-10-2003, 01:31 PM
  #35
hozb817's Avatar
Get the boxed style BMR's, they are strong enough, and will match all your other suspension parts!
hozb817 is offline
Old 12-10-2003, 04:30 PM
  #36
suprchrged400's Avatar
Or 3) I don't have enough torque to twist my camaro but the potholes in new orleans are deep enough to twist my camaro and turn it into a rattlebox(esp. since I have T-tops).
suprchrged400 is offline
Jeff1904
06-05-2016 05:00 PM
Double aught
10-02-2015 11:29 PM
tommalcolm
09-11-2015 03:39 PM
Daluchman1974
09-11-2015 06:12 AM
Bxlt1
09-10-2015 08:16 AM
Quick Reply: Double Diamond VS. Tubular Subframe Connectors HELP!!!
