Double Roller on a 93 LT1
Will a Cloyes Timing Chain set [CL-3145 ] fit on a 93 LT1 with an electric water pump with the original timing cover?
I know that it will work on my 95 however, a friend wants to install a double roller on his 93.
Mike
Mike
Re: Double Roller on a 93 LT1
Originally Posted by Demon's Camaro
No it will not. 93-94 got shafted. You have to get a 95 timing cover only, then all the gaskets and what not.
That is what I thought! Any one else??
In addition to the 95 timing cover, it needs to be converted to a 95+ Opti, including a new piece of wiring harness and a longer pin for the cam. And the early LT1 cams (including aftermarket) didn't have a hole big/deep enough for the 95+ Opti guide shaft, so it may need to be drilled. Don't try doing this with it installed, I did this and got slightly off-center, which shook the Opti to death within 200 miles. Later all aftermarket LT1 cams came with the bigger hole and longer pin.
