Drilling TB IAC hole?
Well my car wouldn't idle for anything after the cam install. Last night I removed my throttle body air foil and it fixed the idling problem a bit. the car still wants to idle very low. My IAC counts wouldn't drop below 100 or so with the TB air foil in but once it was out the counts went down to about 80. I'm pretty sure that I need to drill the hole out in the TB to let more air in but exactly how big do I need to drill it with my IAC counts at 80 now to get them to the 20-40 range. I've read that some have drilled to 7/32 and 1/64. What do you think?? Thanks for any input
I drilled mine out with a 5mm bit and moved it around to make it a tiny bit bigger.. My IAC counts are 30-50.. you dont want them to low either.. Its different depending on cam and stuff.. I would just drill it out a tiny bit and then put it back on and see what it does... Worth the work instead of guessing and then ruining your TB..
how big of a cam? before you drill anything, why arent you working with the minimum air setting? slot the tps screw holes to allow adjustment back into spec. as you open up the blades? the pcm is only going to let it idle where it wants to see it. a big cam is going to want a higher idle speed-that means some limited re-programming is the answer.
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
tdigger9899
09-07-2015 10:56 AM
