drive shaft vibration
ok i needs some help on this one. after my stock trans mount
broke i replaced it with a poly mount. i have had a drive line vibration ever since. the mount came with a pre load spacer and i removed it and that made a differance in the amount of vibration but it did not take it all away you will start to feel it around 65 -70. i know that f bodys had a problem with unblanced shats so i bought another one and had it balanced and new u joints put installed it was worse than the old drive shaft. ok here is the question after searching on line about this problem i ran across a messages board that stated that on 93-97's a poly mount can not be used because it puts the trany at the wrong angle. is this true have i wasted money for nothing?
93 t/a 700r4 3.23 rear end cold air / air foil
flow master muffler.
all i know is that after i installed my prothane trany mount, my car got a nasty vibration at speeds over 70mph. at 110 it feels like somethign is about to fly out. scary. but my stock tranny mounts dont last at all.
i bought an energy suspension poly trans mount and it was garbage. created vibrations all the time. i took the poly one back and put a new stock one on instead and no vibrations what so ever.
when the car was idling, the shifter was getting a lot of vibrations b4 any tampering, but with the new OEM one, it barely moves now. i would just go back to a new stock one if i were you
Yup, it's very common for A4 owners to complain of vibration when going to a poly mount. Had mine for 2 days before I yanked it back out! Get the 1LE rubber one and it'll last longer than the stock one and transmit far less vibration. I've got an aluminum driveshaft, and that by itself will not solve the problem.
taner
09-09-2002 11:36 PM
