Drivers Side Wiper Blade!
my old drivers side blade was starting to not wipe a little square toward the bottom of the windshield probably about 6 inch by 6 inch square. So i figured that i needed new blades. ok so i went and bout some new replacement blades, and put them on. worked fine, wiped the whole windshield and were fine. i just washed my car yesterday and i always lift my blades up to clean windshield/blades. i put them down, this morning there was condensation on my window around 7:45. i was heading to work. use my wipers once to wipe it off and i miss the exact same spot on my drivers side. it is sooo annoying.. it worked fine then 3 days later it doesnt. how do i fix this. i think i am going to bend it down. this is the side in the middle of the windshield next tot the little triangle the two blades make when they wipe thanks!
I HAD THE SAME THING HAPPEN
it wasnt much, but the little bit it was pissing me off, well anyways...when you put down your arm, theres a srping in the arm and it holds it down, push down on that so that its firm against the window and that should help out
ChrisFrez
02-22-2015 08:47 AM
squarehead
11-21-2014 08:02 PM
07-04-2005 05:00 PM
