Dropping the K member
I think i might have to do this to replace my oil pan, so what is involved? Can i just remove the three bolts on each side and let it hang from the struts? Someone help me out here with a breif step-by-step so i don't hurt myself or the car
don't have to unbolt the shocks... just the 18mm k member bolts and the steering linkage (13 mm I believe?). then I guess you could hook up a engine hoist to the top of the engine to support it, while u drop the pan.
If you have an engine hoist there's no need to drop the K-member at all. When i was putting my 383 in i had the pan off two or three times while it was in the car. Taking the motor mount bolts out and lifting the front of the motor up a few inches gave me enough clearance to remove and install it with ease. This was all in my driveway too, so it's definately doable.
Also, i don't know if there is something built in that locates the k-member in the same spot every time, but if there isn't an alignment may be necessary if you drop the k-member.
I was thinking i would jack up the motor with my floor jack, then just drop the K member an inch or so if i have to.
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
[Problem] F-Bodyworld.com/Jon Massaro WARNING!!
DarkKnight
Buyer/Seller Feedback
05-11-2015 10:03 PM
NewsBot
03-30-2015 12:40 PM
