DTC MAF Question
Old 07-02-2009 | 05:17 PM
KYWes's Avatar
DTC MAF Question
Ok, I'm still working on this but thinking maybe a guru will be able to give me a quick answer.
'95 Z28 OBD1 car
I'm getting a DTC 23 error code or as Datamaster puts it MALF 23: MAT Low.
I'll be checking wiring etc. but wondered if anyone's run across this.
For the record I've searched and not found this specific code. Also this is on a car with air pump and EGR removed.
Descreened the MAF years ago but problem is new.
'ppreciate the help offered
Old 07-02-2009 | 06:47 PM
They call MAT as Manifold Absolute [or Air] Temperature. It translates to IAT as we know it.
DTC 23 = Intake Air Temperature (IAT) sensor circuit (signal voltage high, low temperature indicated)
Old 07-03-2009 | 06:47 AM
Next time you need a code for an LT1, click on the "Diagnostic Trouble Code" link in Shoebox's signature.
IgorT.455/406
03-12-2015 03:39 AM
pete53
12-09-2014 07:31 AM
formula218
12-02-2014 04:27 PM
RedLineRev
01-23-2003 03:51 PM
Chrisdude
07-24-2002 02:25 PM
Quick Reply: DTC MAF Question
