Dude with EGR block of plates!!
#17
Originally posted by ledfootz28
revtime,you sure its not emissions legal?i thought getting rid fo the egr and air will still alow you to pass emissions?
Removing or altering ANY pollution control device is a violation of FEDERAL law. Period. Whether anyone notices it is a function of where you live, and whether they do a visual inspection as part of the emissions check, and whether they even know where to look for the EGR valve.
Then there is the issue of actually passing the test. It is entirely POSSIBLE that you can pass the emissions test with no EGR. First, it depends which type of testing they do.... an idle test with a sniffer isn't going to involve EGR operation... it doesn't work at idle. So they won't notice it is missing. A rolling emissions test MAY use conditions that require the EGR system to operate, and if it is not operating, it MAY cause an increase in oxides of nitrogen (NOx). If that increase is just enough to put you over the upper acceptable limit, you fail.
carguyshu
01-22-2017 11:19 AM
stockssn2o
05-25-2015 08:54 AM
