dumb questions
dumb questions
when replacing the rear main seal, do you remove the 4-bolt housing or do you just use a screwdriver and pry the seal out and push another one in?? Also, i just picked up a roller pilot bearing, and i am looking at it and one part of it isnt covered by the roller needles. i'm guessing that the end that isn't covered by the needle bearing goes towards the engine, right?? Sorry for the dumb questions.
thanks,
trav
thanks,
trav
Re: dumb questions
Pry the old seal out with a screwdriver...no need to disassembly anything. I picked up a piece of PVC pipe from Home Depot that was the same diameter as the new seal, taped a flat piece of metal to the end and used this to tap the new seal into place.
Re: dumb questions
i feel like i should know that stuff. It's just one of those things that i made more complicated in my mind As far as the pilot bearing goes, i am just gonna wait until i remove the old one and i'm just gonna pay attention to how it was situated in the back of the crank.
Thanks for the replies!!
trav
trav
Re: dumb questions
If you freeze the roller pilot brg in dry ice it will slip in with your fingers. If you try to hammer it in it will bend the end of the tin housing flat and jam the rollers and the needles won't roll.They make a tool to put them in but 1lb of dry ice with the brg left in the ice in a well insulated container taped shut overnight will shrink it where it will almost fall in. Open it under the car and be quick,it don't take long to warm up.
Warning: handle with gloves and wear safety glasses when breaking ice or handling the parts. The ice will burn you like a torch.
Re: dumb questions
No
But it is a way to do it without damage.
I put the brass ones in like that to, instead of beating the end up with a hammer.
They make a tool to put it in but I will bet it is expensive. A coffee can lined with lots of news paper,some ice in the bottom,the brg,then the rest of the ice,tape the plastic lid on and wa la in the morning it will fall in.
No, a freezer don't get cold enough.
Re: dumb questions
ok, so you think letting it sit over night will be long enough? I've never heard of this method but meh, what the hell. It makes logical sense to me so I will give it a try. So surround it with dry ice overnight in a coffee can, quickly pull the bearing out with gloves and it should just drop into the crank. Give her some time to warm back up then pack it with grease again. I really appreciate the advice man!! thanks for saving me the gray hairs.
Just to make sure, there is no way the roller needles or anything will be damaged by the deep freezing right? One last question, is high temp wheel bearing type grease necessary or can i use just regular grease?
thanks,
trav
thanks,
trav
Re: dumb questions
Re: dumb questions
Originally Posted by tanker
That's the way Caterpillar installs their roller bearing for big machines- freeze them in liquid and just drop them in; was fun to watch when I had a tour through all the assembly line when I did a job interview with Caterpillar. Kind of though I could use the freezing method for my miniature (compared to CAT bearings) pilot bearing. This kind of surprises me that somebody (1racerdude) advises freezing method. It will work for sure, and is a very smart way to do it
I have 38 yeaes experiance with Manitowoc cranes and have been using this method for years. It works on a 1" or 16" DIA brass,roller,ect. bearings or anything with a press fit.
10-31-2016 11:09 AM
Hurin
12-13-2014 07:38 PM
donot_4get
09-14-2002 08:03 AM
