durability: LT1 vs LS1
#76
Originally posted by 2MCHPSI
Both engines are great. Both engines will have lemons that do not last 100k, and both engines will have some that last easily over 200k. For the most part, they are both equally reliable, and each has their own quirks.
both bottom ends are not that great if modding for forced induction. On both engines the pistons are the weak link.
The LS1 clearly has the advantage when talking bolt ons or cams with stock heads..
Both can be modded to hell and both can make a ton of power.
You can't go wrong wth either engine.. I am a die hard LT1 fan and have modded many of these engines in the past. But I would be the first to admit that I would own an LS1 in a second if I wanted to just bolt on some parts and make a ton of power.
#77
Originally posted by ULTIMTEORANGESS
please,give up the BS games.ive given you tons of proof why ls1s are stronger and are more streetable with more hp while all you do is make generalized statements that are not specific that prove nothing.
youve continued to come up with nothing and keep trying to play manipulative games.give it up.
trying to be overly technical is doing nothing to make your case.
#78
what rob raymer did is prove how strong an ls1 bottom end is.with over 130 pulls and making well over 700 hp is proof enough for me.
i guess not for other people.
with better flowing heads its alot easier to make more power and be streetable.
#79
Originally posted by Nestromo
You haven't given me proof of your statement about them being more streetable with more power. I'm not manipulating anyone, and I'm not playing games. I'm not being overtechnical, you are just being under technical. Now please, back up your statement.
ive given examples youve given me nothing but BS.
#81
Originally posted by darrens99formul
Lets just say they are both strong and streetable and let this thread die.
fine with me.but another one will just come up and we'll be at it again.
ls1s are stronger though.
#82
Same with stock bottom ends... It is great that someone had great luck with a stock bottom end.. But most people will not withthat power level. That being said, in my opinion neither engine has a stronger bottom end over the other stock wise in the real world.
#83
and you havent proved that an lt1 is stronger.not even close.please back that up.
I've given examples: Bigger bore, shorter stroke, iron block, stronger valvetrain, less piston speed for a given RPM.
Better flowing heads are a great selling point on the LS1. I will be the first to admit that. The LS1 has a FAR superior cylinder head. BUT.... the original topic here was durability, and a better flowing head doesn't make it more durable, and well ported LT1 heads flow great.... so there goes that theory.
#84
i dont think it was luck at all.it was someone with knowledge and the willingness to try.there was nothing special about that motor.rob knows how to tune and he got the power and proved it could be done.others have made good power too from stock bottom ends and theyve held up.
these rears do suck.mine blew with stockish HP but the guy that tuned my car ran 10s with 1.5 60s' on slicks before his went.i witnessed this.it had several passes on it before it finally gave out.
#85
Why do you have to get so defensive and say that I'm full of BS? I'm not taking any of this personally and neither should you. I don't want anyone to have a coronary here, it's just a little debate. And I would like you to show me some BS that I have written.
you asked what makes able to make more power with streetability.i said a major reason were the heads.and ported ls1/ls6 heads will flow even better.
ive given a durability example already.
youre right and i apologize for using the BS remark.this is all in fun.
#86
#87
the car in question had 130+ pulls on it.if he had others blow he got this one right.its called experimenting.he apparently found the right combo and proved it could be done.
fact is theres not a ton of tuners willing to try FI on ls1s.at least not alot im aware of.people were saying years ago they couldnt stand up to much boost and thats been proven incorrect many times.its a matter of comon sense and tuning.
as far as ls1s having weaker valve trains im not convinced.theyve help up to well over 500rwhp in stock form and a simple thing like a spring swap and theyve held up under alot more.
harlan is another example of a stock internalled ls1 holding up.
theres others i just cant think of any right now.
#88
Lidio ran 9's @ over 140 with a stock 4.6 modular engine... Very impressive but also not the norm or could be considered reliable.. No one is running around saying a 4.6 should handle that h.p. and no one should claim the h.p. on the example you posted as being what an LS1 should handle. That is stretching it, and basically what you are stating in this post.
This has been beaten to death though and I will just agree to disagree on this one.
#89
Brent on Turbomustangs.com has made numerous dyno pulls on his stock bottom end turbo 5.0.... best of which to date is 770RWHP/836RWTQ. Perhaps a stock bottom end 5.0 is the strongest thing out there?
#90
