Dying water pump do it myself or pay for it.gm pump or other brand..??
Old 05-04-2004, 06:57 PM
  #16
80TA's Avatar
Ok did some searching and found out need m18 oil pan bolts plugs and 5/8 inch vacuum cap and easiest way to take off air steel tube is likely hacksaw or just twist it till it metal fatigues.
Guess won't worry about keeping it all mint just find or buy some later on if need be.So would most autoparts stores have these m18 oil drain plugs or do I need to go somewhere special?
80TA is offline
Old 05-04-2004, 07:54 PM
  #17
besz28's Avatar
get a csi electric waterpump their is an awesome right up on installation here just do a look up. plus pick up 10rwhp
besz28 is offline
Old 05-04-2004, 08:44 PM
  #18
80TA's Avatar
Might get a electric later but not right now.
Still have a few questions..how does anyone get the old gasket crap off the block.Its so hard to get at the passenger side with the alt and all that stuff in the way.
Is there something you can buy that will dissolve this stuff away.
Brake cleaner don't seem to do much to it.
Does anyone know the size of the air nuts in the exhaust manifolds can get to them with deep socket now that broke off the tubes and valves in the way.
80TA is offline
Old 05-04-2004, 09:03 PM
  #19
baron4406's Avatar
Originally posted by Bersaglieri
If you think 60k is bad, my opti went at 37k
-Dustin-
Well it was afraid of that long drive to Pa!!!
baron4406 is offline
HectorM52
07-30-2017 11:46 AM
grabbem88
03-18-2015 01:25 PM
ANDYZ28
12-29-2014 09:13 PM
Queens94z28
12-20-2014 09:11 PM
pologreen97z
12-02-2014 10:42 AM
Quick Reply: Dying water pump do it myself or pay for it.gm pump or other brand..??
