Dyno Results!!!!
Dyno Results!!!!
Hello all. Just wanted to post my dyno results and get any feedback you guy's might have.
Dyno is a Dynojet all numbers are SAE corrected
Ok First run with mods in sig, no n20- 282.4 RWHP, 310.5 RWTQ
Second Run with cut out closed- 264.9 RWHP, 296.3 RWTQ
Third Run with 50 HP Shot of N20- 336.3 RWHP, 391.4 RWTQ
What do you guys think?
Re: Dyno Results!!!!
I was pretty impressed with the numbers at first, I thought you were just a bolt-on car. Then I saw a crane cam listed in your sig...I think you need some tuning What are the cam specs?
Yeah, thanks for the reply. I was running in open loop(o2's unplugged) because of tuning issues. The cam's specs are
Degrees Duration @ .050 Int./Exh. - 210/224
Degree Lobe Separation 112
Gross Lift Int./Exh. - .479/.518
all of these specs are with 1.5 rockers and i have the 1.6's. Any suggestions on tuning? I wanna get LT1 Edit.
Shawn
tdigger9899
09-07-2015 10:56 AM
