Edelbrock vs trickflow
I'm installing my comp cam 224/230 536/544 112 and was wondering what you guys reccommend.
Trickflow or edelbrock.
I have a 95 Ta auto with all the boltons longtubes 3000 stall and a 150 shot of juice. I know the trickflow will lower my compression and the edelbrock will raise it. Also the trick flows have bigger valves but I don't want to kill my bottomend torque.
Thanks for the advice.
one more thing should I change my stock injectors. If so what size.
Thanks again.
Joe
Thanks again.
Joe
Given those choices I would pick the Edelbrocks, the Trickflows are more for a boosted 350 or a stroker. Personally though I would work a set of stock heads before going Edelbrock, I just don't see them as being any better than reworked stockers. Plus crap like the fine print that they changed headers between pulls not just the heads and cam, to me the test is invalid then. Maybe someone here has tested them and I missed it, but on the b-body board we have had just a couple people use them and change other stuff at the same time, again not a good test.
Dry or wet shot? I would say 30lbs. SVOs.
sleeperZ96BT
09-09-2015 08:28 AM
