egr delete
Re: egr delete
I have been through 3 EGR valves and the infamous code 32.
When I did my header install I did the EGR deletin with the 3 aluminum plates and had the function deactivated in the tune.
In one case the valve was sticking open causing the engine to barely run after starting.
I dont expect any gains but I do expect fewer headaches.
If the engine is lugged I assume that you are probobly near or at WOT. It was my understanding the EGR did not function near or at WOT. I thought it did its magic when you were basically cruising at constant throttle.
Maybe im wrong.
The other benefit is beacause there is no hot air being introduced into the intake you lessen the odds of the beloved LT1 intake oil leak. I have read that the hot air makes a few bolts loosen up in time causing the messy leak down the righ rear of the block.
Maybe im wrong.
Re: egr delete
Maybe im wrong.
Maybe im wrong.
The people who have worried about the oil leak have come up with the idea of bending the corrugated tube away from the engine (if you have the corrugated tube, and not a rigid one), or insulating it. They seem more concerned about radiant heat from the tube, but I'm not sure I'd buy into that.
Sounds like you've already made up your mind, so do what you want. I was just trying to offer a little "food for thought".
Re: egr delete
Originally Posted by shoebox
It won't have any effect on timing tables, but removing it won't give you any extra performance.
Actually removing the EGR can potenially cause spark knock.. The reason is the computer commands a fuel adder as well as a timing adder when EGR is commanded to keep things smooth.. If EGR isn't there than the extra timing can cause a bit of knock. I just actually helped a guy on Corvette forum with this exact problem.. the EGR wasn't opening with a commanded signal and the car was running up to 12 degrees of retard.
MOST LT1'S are tame when it comes to this and it will never be an issue. But remove the EGR on a older chevy truck and you'll definately have quite a bit of pinging.
sleeperZ96BT
09-09-2015 08:28 AM
