Egr Solenoid
Egr Solenoid
Ive asked this before i know, but i was looking at shoeboxs pictures what is it that acutally come off is it just the EGR Valve in the back of the manifold, because it looks like the only thing with 2 bolts , and it looks like if you take that off your going to have a big *** hole not some little bitty dimond looking thing either. and what do you use to cover that hole up?
yes, there is only two bolts that hold on the egr valve. there should be one vacuum line connected to it also. when you pull the egr valve off, there will be two holes in the back of the intake. they are not really big. you can buy block off plates for this. it is not that big of a piece. the egr valve is much bigger than these holes. people that eliminated the egr will be more help than myself. good luck
Originally posted by frmula1
can't go wrong with duct tape
Use the EGR valve as a template and make a plate out of any metal that is substantial enough not to flex when you bolt it on. A gasket is a good idea too, even if just a piece of gasket material from a sheet. No need to worry about the holes except for the bolts to go through.
What do I do with, the I think its the A.I.R Hoses the black ones coming out of the manifolds, do i go all the way down to the bottom of the engine and take them off or what? Im just trying to take my time and not mess anything up along the way thanks.
jackpawt883
09-10-2015 08:53 PM
350350
14
08-11-2015 12:03 PM
