EGR Valve / Detonation
I have a 93 Z28 and recently had a fire underneath from a bad Cat-converter, the fire screwed everything up, so I removed the CAT for a straight pipe, and I've change the speed sensor, its wire harness, the shifter cable, and the vacum lines to the EGR valve. The EGR will not hold any pressure pressure at all though and I'm getting detonation. Is there any way to easily remove the EGR valve? It's exetremely hard to reach considering it's DUMB location!!!!
Also, does anyone have any suggestions on anything else that could be causing the detonation? I'm pretty sure its the EGR considering when I'm on the throttle I spit out white/gray exhaust.
PLEASE HELP
PLEASE HELP
Got the EGR Valve changed but there is still detonation. Could that be caused from a lack of back pressure due to having no catalytic converter on the exhaust?
Exhaust is the following: K&N mass air-flow package, Edelbrock headers, and no catalytic converter. The rest is stock (93 Z28)
When headers are added and/or Cats removed it is "very common" to have a DTC (code displayed) related to the EGR (I'm too lazy to look up the actual DTC #). Which is due to a lack of EGR flow and caused by "no exhaust back pressure."
WD
WD
But it doesn't cause detonation. if hes hearing detonation hes got serious issues somewhere.
You wont get detonation from no exhaust backpressure. If it throws an EGR code after removing your cat and you know your egr valve is still functioning then that is caused by reducing backpressure, however it still wont induce detonation. your detonation is likely caused by something unrelated to the EGR valve but likely related to the fire. Are you sure its detonation and not something more serious like a knocking rod?
14
08-11-2015 12:03 PM
RX Speed Works
07-24-2015 02:25 PM
