Eibach Drag Launch Kit
#31
I never said it was unsafe. regular street diving is fine.
No front sway bar and skinnies with drag radials on the back your not going to want to do any solo racing.
I have seen first hand the carnage that can occur when people think they can take the curves like they used to with a car modified to go like hell in a straight line, it can get away from you and it usually happens so fast when it does that its too late to do anything about it.
I am not trying to scare anybody but I don,t think its right to tell people that thier car will handle like stock with a removed front sway bar and skinnies.
Just the drag launch kit itself with everything else being equal would be fine on the street but if your going to install a drag launch kit then why would you not set the rest of the car up to launch?
#32
I guess my point is that all of us have very specific needs. No one specific suspension is gonna be ideal for everyone. I just wanted to point out that drag launch springs do not degrade the handling of an f-body to where most people would notice. Before I ditched the front sway bar and with a 24mm out back and drag launch springs all around, my car definitely handled as good as it was stock with my current tires.
#33
Originally posted by brokenz
Remember in the front and rear we are talking about really stiff springs here.
Also, it was my understanding the v-6s rear springs were softer than stock, and the exact opposite of what you'd find in the drag launch kit.
#34
Originally posted by speedmiser
The front springs should be softer (less stiff than stock) with drag springs, not stiffer. Good for front to back weight transfer, but really bad for handling the rest of the time.
The v6 springs are definitely softer. You would think that this would actually hurt traction but for me it's not the case because I can actually "feel" the tires when I launch it now. It's the complete opposite of what it should be but trust me, I've been playing with different springs for a long time now trying to get the car just the way I want it. Maybe for someone else this wouldn't be the case but for me it is.
#35
Odd, I'd heard that the front springs had softer spring rates which allowed for better seperation.
"Relatively soft front spring rates allow maximum weight transfer when launching. "
http://www.lmperformance.com/547/2.html
#36
#37
Thanks guys! I'll be gettin the drag launch kit, some bilstein shocks, bmr torque arm, bmr control arms with lowering brackets, and a bmr panhard bar....it should start hooking up now....thanks!
#38
Re: Eibach Drag Launch Kit
dont forget to get some Drag Radials, I have had both Nitto and BF Goodwrich, stay American Made! Go with the BFG! By the way, do you have any install instructions on the drag launch kit?
carguyshu
01-22-2017 11:19 AM
05-21-2015 01:04 PM
12-01-2014 08:08 AM
