Electric water pump help!!
Does anyone have any diagrams on how the maziere electric pump is wired to it's relay? Which out of the four plugs on the relay does the red wire connect to and which does the black connect to before it's grounded?
And my radiator is making burbing and gurggling sounds aswell. I purged the system and it still makes those sounds. I think my pump may be wired wrong and is spinning in the wrong direction. Can anyone please help me so I can drive my car.
Re: Electric water pump help!!
Here is a diagram:
http://ken.lowrance.com/Projects/CSI...ectricalHookup
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
My car also makes thoose noises, both when hot and just killed, or just pumping cold sometimes, so I assume its normal, been that way for at least 15k, perfect running temps.
Thanks for those diagrams.
After you fully flush the system you'll have to "burp" the system. Meaning bleeding it several times. You won't be able to get all of the air out till the thermostat opens.
-B
-B
