Electric water pump leak?
Old 04-18-2007 | 03:42 PM
Vicious95Z28's Avatar
Just wondering if any of you guys have ever encountered a CSR pump leaking from the mating suface. If it continues I may just use some gasket paper and eliminate the o-ring altogether
Old 04-18-2007 | 05:09 PM
Heatmaker's Avatar
Advanced Member
If it's leaking the O ring probably came off track, the housing that the pump slides into may be nicked and allowing coolant to seap through. I always use a nice layer of RTV around where the o-ring goes. unless your o-ring is faulty, you really shouldn't be having those problems at all.
Old 04-18-2007 | 07:18 PM
BlackScreaminMachine's Avatar
I used rtv for extra insurance
Old 04-19-2007 | 07:00 AM
Yeah I guess I put too much trust in a tiny o-ring and an imperfect aluminum housing.
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
Queens94z28
12-20-2014 09:11 PM
Zone
07-29-2002 07:43 PM
Quick Reply: Electric water pump leak?
