Electric Water Pumps
Anybody put one of these in a race car and just hooked the ground to ground and the hot to a toggle switch on a fuse?
I am confused by all these installs with instructions to hook it up to the air pump harnes....which is long gone in my car.....or other ways with relays, but it seems overly complicated for a stripped race car application.
Anybody done it?
Thanks...
Anybody done it?
Thanks...
its really not hard to wire the relay, all you need to do is hook the relay to the pump, run power and ground to the relay and find a power source that is powered up when the key is turned on, the easy way is to tap into a fuse under the hood... do a search there are a lot of write ups on it
i have mine hooked up in my race car to a fuse panel then to a toggle. either use a lighted switch or add a light to the switch.....I would no tap anything to your fuel pump...you want that to get full power...same for ignition
