Eliminating EGR and AIR
If I install TPIS Long Tube Headers, I will have to eliminate the EGR valve system and the AIR injection system. What do I need to do this? Do I need a tune? Just looking for some simple instructions
I just did the same thing 2 weeks ago. I sent my computer to pcmforless and I don't have any problems. Just block off the back of the intake and get you computer programed and you all set. You can make your own block off plates its easy.
Originally posted by AdamZ1LE28
And just remove the AIR pump and all its hoses? Or do I need programming for that too?
in OBD1 cars you can remove it as long as you leave the fuse in place.
Some good reading about this topic.. http://web.camaross.com/forums/showt...m&pagenumber=1
95chwagon
01-13-2015 09:19 PM
MIGHTYMOUSE
08-29-2002 09:18 AM
