Engine Block Identification, Help Needed!!!
I recently purchased a bare LT1 block and would like to know what year the block is and what car it came out of. I have searched this topic and found a picture someone posted but still can't quite figure out what I need to know, can someone shed some light on this situation?? The numbers on the block are as follows.
Pad, on right front of block: V0327XPN
Near oil filter: 162196337
The 6 in your number by the oil filter is probably an S. That would mean it is a 1995 if out of an f-body. I don't know if the B any Y body cars had the exact same breakdown on that, but suspect they do. The first digit (1) means Chevrolet.
http://shbox.com/1/block_vin.jpg
Why does it matter where it came from? There was one LT1 block, only difference you will find is the Vette and warrany motors had 4-bolt mains put in the SAME CASTING, even the LT4 is the same block again machined for 4 bolt mains.
F'n1996Z28SS
08-23-2023 11:19 PM
07-04-2005 05:00 PM
