Engine Issue
Engine Issue
After changing out a motor mount, I decided to remove my air pump. The car now will start, but as soon as I let off the gas it dies. I am also now having an issue where it back fires. The backfire seems random, i had 2 in 5 minutes that were maybe 15 seconds apart. I was going to try putting the pump back on to see if it went back to normal. Any other ideas?
I will check that, I think I had everything square. Speaking of vacuum, do you think the vacuum line going from the air pump to the hvac/evac solenoid could have done this?
Alex Barnes
01-24-2015 10:21 PM
01-05-2015 07:14 PM
