Engine out from the bottom pic
I used the shop crane that you see in the pic - orange on far right side. The 2x4s are not stacked. They are held together with wood screws. I used interior stud 2x4s because they are pretty light and I didn't want to drop one of my hang-downs into my sock when I picked it up to move around.
Good engineering on the stands, probably a couple of different places use them, maybe like rebuilding the rear end. I need to pull my worn out 10-bolt, I think I'll build some.
i got a 95 z28 that i just pulled the motor out of. The motor can come out of the top. All you got to do is remove the radiator, all your pulleys, and intake manifold and it can come out the top.
I didn't jack the car anywhere near that high when I did it. I pretty much just pulled the body up with the engine hoist and put cinder blocks under it, but whatever works.
You don't need all that wood under the front either. I used a decent size pair of jackstands (normally used with my 4X4) and it gets the front plenty high enough. If you remove the front wheels, you can lower the car down onto a dolly, reach in and pull the 6 bolts holding in the K member and then lift the body using an engine lift and slide the whole damn thing out in one piece. Really easy to do....
F'n1996Z28SS
08-23-2023 11:19 PM
