Engine Overheating
Engine Overheating
Just a little follow up on my last post. I was asked to bleed the coolant system with the two bleed screws while the engine was running. Well, that's what I did, but no liquid came out of either.The temp gave was where it usually is under normal running so the thermostat should of been open, as well this is a new thermostat that was put in around november.
Tnx for the info,
J
Tnx for the info,
J
Originally posted by teke184
hm..if no coolant came out that would mean air came out...right?
so that is a good thing...you opened them when the car was good and warm from driving?
well, I checked it and the fluid seemed full, I had my thermostat changed by a garage in november and they said that they change my radiator fluid, so being cloged kind of seems feasable at this point.
Dan_the_ManZ28
02-21-2015 02:01 PM
JasonD
08-23-2010 03:14 PM
Caps94ZODG
22
07-30-2002 08:45 AM
