Engine Removal, Quick Question
Old 01-29-2011, 12:53 AM
  #16
SkiBumDreams's Avatar
Re: Engine Removal, Quick Question
heres my thread about the same subject
https://www.camaroz28.com/forums/sho...d.php?t=587100
SkiBumDreams is offline
Old 01-29-2011, 06:57 AM
  #17
Rich2279's Avatar
Originally Posted by Injuneer
A4 or M6? Do you mean unbolt the bellhousing from the engine? Tilt tailshaft down, being careful not to force the oil pressure sending unit into the cowl. You can push up gently on the front of the engine to tilt the tailshaft down more.
A4 trans. Yes, the housing bolts are hard to get leverage on them. I tried removing the upper bolts w/ a wrench. So, I need to remove the driveshaft, unbolt torque arm, and trans mount to tilt it back?
Rich2279 is offline
Old 01-29-2011, 09:29 AM
  #18
1badasZ's Avatar
Originally Posted by Z28Roxy
K-member is 3 bolts on each side, very easy and you don't even have to get under the car to take them out.
Intake does not have to come off until it's out of the car.
Hood does not have to come off, neither does the bumper.
after doing so what do you hook to on the car to pick the car up?
1badasZ is offline
Old 01-29-2011, 09:52 AM
  #19
RamAir95TA's Avatar
http://www.michiganspeed.com/enginepull/index.html
You hook the straps/chains to the two front frame rails.
RamAir95TA is offline
F'n1996Z28SS
08-23-2023 11:19 PM
97SSdude
12-31-2014 07:43 PM
cmdeshon
12-27-2014 10:06 AM
pologreen97z
12-02-2014 10:42 AM
Quick Reply: Engine Removal, Quick Question
