Engine Ticks at High RPM?
#16
The problem turned out to be the #5 intake rocker somehow loosened and popped off the valve head. Only the side of the rocker was pushing the valve down. I know I tightened the lock allen screw. If it does it again (and doesn't destroy the engine in the process) I'm switching to hardened pushrods and guides, and some new rockers. Oh, and I also shot some air down the pushrod. On startup everything was fine and I pushed the revs over 5k and check the rocker one last time before I buttoned it up. Crossing my fingers...
Hal
Hal
If that's the case, you're really lucky, because that can cause the locks to pop out and drop the valve.
I wonder if that's why CompCams recommends NON self-aligning rockers/guide plates and hardened rods in performance applications.
Jake
West Point ROCKS!
#17
Are you saying the rocker was opening the valve by depressing the retainer, not the valve stem tip?
Jake
West Point ROCKS!
Jake
West Point ROCKS!
The lock allen never did make that much sense to me. I guess it's super important that you tighten the lock allen while holding the outside nut in place so they don't turn together that last little bit. That way the locknut is actually using a binding action that may provide a real lock.
Hal
#18
Sorry, what I meant to write was the rocker side was pushing the valve STEM down. Yeah, I don't know if I like this SA set up anymore.
Hal
Hal
I'm glad to see it was something as simple as a loose rocker.
#19
The technique I use involves setting the preload, tightening the allen lock screw and then turn the whole lock-nut set-screw assembly about a 16th of a turn. That jams everything together and has held for quite a while now. I think simply tightening the lock screw down doesn't provide enough 'force' on the union...
page 2, step 4
http://69.20.53.62/pdf/425e.pdf
Hal
#20
I need to make sure this is done right. I'll go back out and do it that way. I certainly don't want to ruin my engine because I was being lazy. Crane just recommends you hold the nut while you tighten the set allen.
page 2, step 4
Hal
page 2, step 4
Hal
Anyway, a little turn with both the polylock and the set screw won't hurt anything...even if it doesn't help....chuckle.
#21
Jake
West Point ROCKS!
#22
importkiller94
01-17-2015 09:03 PM
centric
08-15-2002 09:04 PM
