View Poll Results: Has your electric water pump failed?
Yes
20
26.32%
No
56
73.68%
Voters: 76. You may not vote on this poll
Everyone with a Electric Water Pump - VOTE!
#17
Meziere #1 : (HD version) 24 months service (to the day!) with a little over 20,000 miles pump quit... turned out to be an internal wire that was put on poorly on a batch of pumps made.... they fixed & rebuilt the pump for free, still going strong today.
Meziere # 2: 35,000+ miles & still going strong... but I do keep a spare under the seat I just want to see how far this one will go.
Meziere # 3: 7,000 miles so far so good.
Over the years I've installed about total 15 Meziere & maybe 4 or 5 CSI LT1 pumps. I had only one out of box failure which was a CSI & one of the other HD Mezieres had the same loose wire problem I had on my first one... both of those were purchaced at the same time.
I'm pretty happy with the Meziere's over all & will continue to use them
As a side note..... I will say that A: throw away the fuse that comes with the pump & use a better one. For some reason, I found that the fuse that comes with the kit blows well below it's rating..... Also, double & tripple check your connections to make make sure all is secure and everyhting should be OK. The majority of the problems I've seen were install related wiring problems
#22
Re: Everyone with a Electric Water Pump - VOTE!
-Dustin-
#23
I'll stick with my stock water pump thank you. 5yrs and 80,000 is a much better track record then any electric pump I've seen. Even if it is leaking I know it is still work and not going to blow a fuse.
#24
#28
Originally Posted by Bersaglieri
Thats a pretty impressive track record with E-WP's. Do you feel Meziere's are worth the $50 more though?
-Dustin-
-Dustin-
