EWP wiring question
in the fuse box...the entire left side i believe has no fuses in it, buta ll get power when the key turns on...just put an inline fuse to the pump from that, and ground it out near the fuse box, youll be set!
if i was doing it, i would take +12V from the distribution block under the hood (the nut and stud that has the red cap over it) and use +12V IGN from the fuse block to energize a relay that closes the circuit between that distribution point and the EWP. i don't know exactly how much current the EWP will draw, but i'm sure it's more than i would want to pull through the fuse box all the time.
my
hey MEAN, whats up?? i'm from goshen, but i'm going to school in fort wayne now. later!
my
you can do it that way, and it wouldent drawl it from the fuse box, not a bad idea...actually better than wat i suggeseted...but half the car is run out of the fuse box, so i figure it would have plenty enough to power the water pump...
Jegs website says the Mezeire LT1 EWP comes with a 20 amp fuse. So I guess you probably could use the fuse box for that considering under normal operation it will pull less than 20 amps. Either way would work.
I have mine setup like mmmchickenboy stated.
Take a look at this schematic.
http://ken.lowrance.com/projects/CSI...mp/Default.htm
The green area is for an optional switch...it didn't use it but it might be something your interested in.
Some pics of the install can be found here:
This is the correct link to the schematic that GetaZ screwed up
http://ken.lowrance.com/projects/CSI.../Schematic.jpg
Thanks guys. I ran out of time last night to do the wiring so I just quickly hooked it up to the battery and just unplug it when I turn off the car. I'll probably just run it off the fuse block since it must not draw much voltage considering it only uses a 20 amp fuse.
I'm the east side of Elkhart, but I went to school at Concord and was around Goshen alot. what do you drive? I may have seen you around.
Cool my dad went to Concord. I used to live across the street from penguin point on goshen ave and middlebury st. i live out by middlebury now. ive driven a white '99 TA and black '77 vette recently. Actually, did you ever see that white '99 TA that I ended up buying? It was for sale at the car lot at toledo rd, goshen ave, and indiana ave. I got that thing for CHEAP!! '99 TA M6 83k miles for $7,500! What do you drive? Later!
lbrowne
11-13-2011 04:25 PM
