Exhaust Manifold question need a little help?
I had to replace the passenger side Exhaust Manifold because I had a stud brake off and had a bad leak where the exhaust pipe connected to it.
Can I re use these stock Exhaust Manifold gaskets?
They look good and no leaks.
There 3 pieces of metal I just taped them because they were coming loose.
manifold side
engine side
Also is there an easy way of connecting the EGR pipe back on it was very hard to take off?
Does any body know the torque for the 6 Exhaust Manifold bolts?
Thanks,
manifold side
engine side
Thanks,
