exhaust. what do these word mean?
1995 camaro z28 v8 5.7 350. all stock
im planing to buy an exhaust system.
heres the link http://www.pitstopautoparts.com/cata...y=1&make_code=
its the 2nd one . the one in the bottom
i needa know what the = MFI, VIN "P" mean and if it says it fits a daul catalytic converter, does that mean i need to have 2 catalytic converters already installed?
Re: exhaust. what do these word mean?
Sometimes the pictures they use arent for that application. That second exhaust looks like it would fit a 1st or 2nd gen fbody. youre going to only need one catalytic converter for your basic catback system. the first picture is what would fit any 4th gen LT1 fbody.
thx aguyz
i dont know much about camaros or any other car. so im still learning.
i also wana now the yrs and generations of each camaro. so if i dont even have a catalytic converter.
I 1st have to get one then the exhaust system right.
Originally Posted by davidc212k
thx aguyz
1st gen. = 1967-1969
2nd gen = 1970-1981
3rd gen = 1982-1992
4th gen = 1993-2002
5th gen = 2009+
You should already have a catalytic converter on your car. so when you buy a catback system it replaces everything from the catalytic converter back to the tips. That little annoying hump in the front passenger side floor is where the cat is on the exhaust system. Look under your car to see if its there. If you dont have emissions testing in your county/state then if its not there dont worry about it but you could remove it. If you do have emissions you can buy a hi flow cat or gut it. If you have anymore questions just ask, thats what this sites for.
EDIT: Check out Wikipedia.org you can learn alot about fbodies and all the generations and motors that were on them. Actually found out that the LT5 was co designed by Lotus.
Originally Posted by Severous01
second is actually for the vette. buddy installed his the other day on his "new" 98 he bought.
i take it that this is the catalytic converter.
so all i need to buy the exhaust system kit, right.
Can i have to catalytic converters on my 1995 z28?
What are the catalytic converters for anyways?
Yes that is the converter. 93 to 96 had only 1. 97 is the first year they put 2 on. all you need to buy is the cat-back exhaust kit and that will replace everything behind the converter.
and im not really sure what it does..it takes some harmful chemical out of the exhaust gasses or something like that.............really all its doing is restricting your exhaust flow and cutting power...cut that jank outta there
