Factory Roller Lifters?
Re: Factory Roller Lifters?
130-140 lbs, although I'm sure they could handle more I'd be looking for a Comp R because I know they can take it.
Get as much weight as you can off the valve-side of the valvetrain and you're springs will be better off.
-Mindgame
-Mindgame
No... that's open. Closed is around 5-6 lbs.
You have to go with experience. My comments are just guesstimates but based on my experience, I know the Comp R's will handle upwards of 400 lbs open so that's the route I'd take if I were getting close to that.
By all means yes... you will see good performance with more spring. It's better to have a little too much than too little in this case.
-Mindgame
-Mindgame
