failed emissions
#31
Re: failed emissions
I failed the emission test to I live in Stafford,Va. I have a 94Z28.
15MPH
HCppm-Limit-96 Reading-263- failed
CO%-Limit-0.53 Reading-0.81-failed
NOppm-Limit-733Reading-1898-failed
25MPH
HCppm-Limit-93 Reading-268-failed
CO%-Limit-0.52 Reading-0.80-failed
NOppm-Limit-664 Reading-1381- failed
Overall Test Results Failed.
The person at the test shop said he could tell by the test that the Cat was Gutted out.
15MPH
25MPH
#33
i checked my fuel pressure again the right way with the vacume line off and it was really high so i turned it down. I also noticed that some gass came out of the vacume line. i dissconnected it from the end that is attached to the intake and after adjusting there was a little pool on top of my intake. Also i got my car scanned and there were no codes and i was getting good signals from the O2s.(or atleast i think it was jumping around from 50 or so to 900)this was at idle by the way.
So its prolly the cat. I'm gonna get some slp headers y pipe and a carsound cat.i'll post if i pass after
thanks alot guys
thanks alot guys
#35
You should never have any fuel coming out of your adjustable fuel pressure regulator. If you do there is a hole in the diaphragm inside the regulator. This would cause your fuel pressure to be unregulated and you would get raw fuel dumped into your intake via the vacuum line. This would cause you to run rich for sure. If this has been going on long enough it may have taken out your cat.
Sounds to me like at a minimum you need a new regulator.
#40
Great News!
I just took the CA smog test this week. What a PITA!!! I had them do a pretest and I'm glad I did because I failed. I forgot about the block off plate being wide open. So, the egr wasn't woeking, do to the lack of back pressure. When I put the fully close plate it passed. It taek them a couple of tries, though.
sleeperZ96BT
09-09-2015 08:28 AM
