fan fuses keep blowing
i was out in my car last night and when i was sittin in traffic my temp was rising, poped hood and fans werent on and fuse was blown 10a fuse, replaced it and the more i drove it the more it happend so i took it home, fans move freely checked with other relays, same thing, but i also noticed that my 02 wires on the passenger side was dragging on the ground, (tie wrap must of broke off) if the wires on the 02 sensor was shorting out, would that cause the fuse to blow?
also noticed my radiator side is starting to split and crack (passenger side 3" under the cap, im gonna get a new one but is it worth getting a be cool or any other fancy expensive radiator or will a autozone replacement or oem be good enough?
thanks guys
thanks guys
Yes the same thing happened to me my o2 sensor had a wire shorting out and it was causing the fan fuse to blow. I didn't even have to start my car for the fuse to blow even if I just turned the key to the on position it would blow the fuse. the best way to see if this is the problem is just to unplug the o2 sensors and see if it still blows if not you know your problem. Good luck
