fan relay bypass?
#17
Re: fan relay bypass?
Thanks 93z, did they tell you how much it cost including labor? or can we just buy outside. my ignition key has this key chip that I do not know if we need the dealer to calibrate every component?
#18
Shoebox- no they do not.
Jcatelo-i wouldn't go straight to a shop its probably an easy fix just hard to trace down the problem. As far as pricing idk it probably depends where you take it
#19
I think when I originally did it, I wired the dark green and dark blue wires at the fuse box to one side of a double pole switch and the other side to ground. So when you throw the switch, the relay coils get the ground and the fans turn on. Otherwise the switch is open and the computer controls the fans.
#21
You need to take a schematic and prove where the trouble is. You need to see if the ECM is putting out a ground to the fans when the fans are commanded on. Don't assume anything is wrong until you prove it is.
#23
07-04-2005 05:00 PM
