Fan switch pics
Thank you Shoebox, I have a 94 z28 and my fans will not turn on. Check the relays change the fan motors. I even scan the car with and auto xray and the car showed no codes. Change the sensor in the water pump also. When I turn the A/C on the fans still will not kick on. The only time they will work is when I unplug the MAF sensor. Need help for this one.
