Fans driving me insane...
#16
Are you on a stock PCM? It sounds normal to me(the fans turning on at 3/4 with a/c off). Stock, the fans don't turn on until 226* for the first stage, and 235* for the second stage. If you want your fans always on, leave the a/c on, or get a 160 thermo and get the pcm reprogrammed(maybe a hypertech).
#17
Well, the switch does not seem to have any effect on the fans at all right now, when the fans are on I can get the light on my switch to come on, proving continuity, even though power is going in the wrong direction
But when I turn on the vents the fans go on at low speed (I think, car ran cooler when I had my switch hooked directly to the fan wires), and even if I turn the dial back to off the fans still stay on until I turn the car off.
Are the relays hardwired to something in the ac or vent system? Or does turning on the vents send a signal to the ecm, and the ecm turns the fans on? Basically what I'm asking is are the vents and temperature fan on operations on separate systems, or are all aspects of normal fan operations controlled by the ecm?
If they're separate, the temp sensor wires could be bad, or the wires from the ecm to the relay. If they're together, then the ecm must not be getting signal from the temp sensor which would of course mean no fans (could also mean my timing could be a little overagressive if the engine is around 210 degrees).
Does this help?
Does this help?
#18
BTW, with vents off I sat there and watched the needle on the temp gauge go all the way to 3/4. I assume the fans are supposed to kick on before then, right? Not that much to go then before it makes its way into the red...
#20
I hope not...
The only wires I've messed around with are the ones to the fans accessed from under the car, and the blue and green wires- I used t connectors so all of them still have original connectivity like they're supposed to...
I started having this problem after my cap & rotor change (done by a trusted mechanic), they said they noticed the engine was running hot, but didn't try to diagnose the problem, they only fix what you tell them to.
I'll tear into it tomorrow afternoon and see if I can pinpoint any problems...
#21
I woulr really consider riping out the old wireing and get it all back to stock.. make everything work from there and then rewire the switch up the right way. With the bad wireing that was in place it;s gonna be so hard to really overcome the problem
#22
Factory wiring is back to stock, except for tapping into the relay wires- since the fans still turn on there is still continuity.
Tomorrow I'll change the wiring for the fan switch to the correct position and then troubleshoot the factory wiring to see what's going on. Not much else I can do, unless I want to rig up my own separate fan control system, which would be harder than it sounds.
ChrisFrez
02-22-2015 08:47 AM
[New Jersey] Cure those winter blues with the NJFBOA!!!
njspder
Middle Atlantic
01-08-2015 11:13 AM
