Fans not coming on...
i've searched but couldnt find answers to my questions...
96 LT1, m6
computer has been programmed to turn fans on @ 180*
all of a sudden they stopped working; i have checked fuses and relays; A relay was bad so i switched in the fog light relay.... but they still dont seem to turn on.. I have let the car get as hot as 230* and they dont turn on. I have tried turning on the ac but still dont work....
Is there a way to check and see if the fans are actually getting any power....
or can i directly give the fans power and ground to check to see if they work, im afraid that they will burn out if i do this....
with a test light i have checked all fuses and realys and they do get power.
96 LT1, m6
i know i have an obdii... How do i jump pins 5 and 16 in order to check to see if the fans will work???? a piece of wire???
if i am able to get my car scanned where/what should i look for on the scanner???
after i found out that one of my fans was burned out... a friend let me borrow his set.... i plugged them in, and still dont work!!!
i hooked one of em upto the fuse labeled 'ignition' and turns on to high speed when the key is forward... what gives!?!?!!
Check your continuity to ground. You could have a ground problem. Also, be sure and check all your fuses. The fuse that the air pump is on, is the same one for the cooling fans. If that fuse blows, you will throw an air pump code.
You could also have a bad temp. sensor. There are two coolant sensors on an LT1. The gauge sensor is in the side of the drivers head. The one for the computer is in the water pump. You could have some type of issue with that one.
Some scanning software, like Autotap, could help you see that issue quick. If all is fine with them, then the temp reported by the CPU should be close to the gauge temp.
thanks for the response....
how or what should i look for when/ if i scan the car.... the SES light is not on; so if i get it scanned what should i be looking for??? Which of the two sensors should i change out first.... the gauge in the dash is reading correctly... should i first change the one on the water pump???
Also read this http://autorepair.about.com/od/elect.../aa032903a.htm
Even if the temp sensors were bad I believe the fans should still come on with the AC. You've tried other working fans so that tell's us your fans may be okay. I would double check all the fuses and relays. Test the fuse or replace it even if it looks good. Make sure you have the correct relays for the fans. Also look for a bad ground. It's easy to miss a loose or cut wire somewhere. I don't think a datalog will tell you much unless there was a DTC error that is no longer being displayed on the dash. But if you unplugged the battery it's probably gone anyway.
Here are the Fuse block details and coolant fan schematics....
http://www.ace1252.com/images/Fuse_B...tails_1996.JPG
http://www.ace1252.com/images/Coolan...matic_1996.JPG
The pictures are big, but they give good detail.
Be sure to check "Fusible Link C". If you had a fan go bad it could have blown that fuse.....if it is okay, then time to start tracking things with multimeter.
well thanks for the schematics!!! I'm not too good at reading them though. I rechecked all the fuses and relays, and i changed the sensor on the water pump yet still no workie on the fans.
Since i couldnt figure it out this is what i did for the mean while... I spliced into the power wire on the fans, and ran a wire into the fog light relay... so that when i turn on my foglights I manually turn on the fans...
Dont know if this is safe, but i'd rather hook them up this way then directly to the ignition etc...
Magenta_Hearts
03-29-2017 08:54 PM
DropTop91
22
08-08-2002 10:53 AM
