Fans Won't come on...
The cooling fans are not turniong on when the car hits the temp. for them to turn on. The car was almost to 210 deg and nothing was happening. I checked the relay by swapping it with another so I guess that is not the problem, and I know the fans work b/c I have a fan switch for the track and the fan works when I throw the switch. Help... Please....
Re: Fans Won't come on...
I can get a scanner on monday to check it out I had the SES light come on also, But I thought it was because I was running racing gas the night before and it might have thrown a code b/c of the lead in the gas. Could a bad sensor throw a code?
Magenta_Hearts
03-29-2017 08:54 PM
