Fastest Bolt on LT1?
#18
turbos, superchargers, cams, heads, 12 bolt/9 inch, are also considered bolt ons. and I've seen some hitting 9's. I want a list on what's considered bolt ons and what isn't, it's very ambigious. If you are talking about the most you can get out of the car without increasing the CI then there are also 8's out there.
#20
i went 12.700 @ 107.96 in a 3620lb convertible with longtubes, aluminum ds, subframe connectors, tubular lcas, re-loc brackets, 4.10s in a 10-bolt, shifter, k&n cai, and madz28 tuned.
Drove it an hour and a half to the track, ran without changes, and drove another hour and a half directly to work for an 8-hour shift, and finally home(another 20min).
edit: that pass was at +310 DA...with some 1.6 rockers, an electric water pump, a torque arm, some better driving, and some better weather(my buddy got some -1xxx DA a few weeks later at the same track) I have no doubt the car would have gone low 12s
#23
#24
I knew someone was gonna say it rofl.
The term bolt ons is highly debateable, some people consider N20 a bolt on, others do not, some consider turbos/superchargers bolt ons some do not.
IMO if a turbo or a super charger is "bolt on" then you could make 1 pass with a car running rediculously high boost and go into the 8's, of course the car would die at the end of the track, but it was just "bolt ons" same goes for N20. But to all there own.
#25
that is a good question lol, im not sure why people consider "some" stuff bolt ons.
#26
shon herron
www.herronperformance.com
look under shop car.
he's also pretty much the cheapest for alot of parts. he's a sponsor here too.
i think he ran 11.80 in his bolton LT1. w3rd.
#27
The key is making use of every HP that the motor would put out. solid everything and good air on the best track around (carolina dragway).
Even with the carpet, and interior panels I am pretty sure it would still run in the 11.8s, considering it had never been tuned with a WBO2, just tuned by feel
Someone else try to get the LT1 Bolt on down to 11.7s, I know it will do it!!!
#30
Car was 3100ish with 230ish driver.
