fastest gm847 cars
fastest gm847 cars
im redoing my 383 with a gm 847 and wanted to see how fast cars were going with similar mods...i have a 3200 stall, great suspension parts, and approx. 3350 raceweight (stripped car) and my 383 has ai 190 cc heads. i know one guy has run 11.15 with a 306 but anyone else to low 11's or think this car could run that?
Re: fastest gm847 cars
thats awesome 11.06!! a lot of people are saying it'll only run mid-high 11's so its good to hear you have had better luck...can either of you guys pm me some more specs on your cars so I can check my setup?? thanks a lot!
The biggest Obstacle my car has is that my present motor only has about 9.8:1 compression. I know Jeff has closer to 12:1 and his car is lightened.
He also didnt mention that his 11:06 was on a HOT HOT day. In some cold air it would run well into the 10s.
My low compression car ran 11.50s cosistant on a 85 degree night with about 100% humidity (1200 foot ele). I would like to hit the track on a 50 degree night to see how it does, but I have a higher compression motor in the works that will be done by then. (moving up to 11:1)
Originally Posted by Z284thgen
search my SN for results on mine or see sig
Originally Posted by My Iroc Z28
Those are some nice numbers, what kind of weight reduction do the cars have?
Jeff I beleive has alot more done, but if I remember correctly he is still in the 3400 range with the driver.
Jeff would have to chime in on what he has done.
My car traps anywhere from 118 to 120 mph , depending , so its moking in the 400 rwhp range (probably on the low side, But it has tons of torque, especially from 2500 to 4000. If you start anywhere from in there the car has massive problems with traction.
Originally Posted by Jlo
That's quick, I saw the video, you're car looks wicked. I have that video on my bookmarks but I can no longer see it any chance of posting a new vid.
good info to have gentlemen...so its safe to say that it should be a solid 11.50 car, if not faster on a 50 degree october night with awesome traction??
Originally Posted by WS Sick
My car only has lightweight wheels, and the front sway bar removed.
yea, any chances of that?
http://www.ls1tech.com/forums/showthread.php?t=260288
click on the car pictue on the bottom.
