fastest gm847 cars
Old 07-31-2006, 06:17 PM
  #16
Matt1997Ta's Avatar
Re: fastest gm847 cars
I think jeff had a street twin at the time.
Matt1997Ta is offline
Old 07-31-2006, 06:20 PM
  #17
redneck01's Avatar
holy crap...thats pretty fast for that cam...whats the secret? thats the question
redneck01 is offline
Old 07-31-2006, 06:29 PM
  #18
hsyr's Avatar
Originally Posted by calfirebird
Mine with Le2 heads makes 417rwhp with a 2800 and all i can manage is 11.80 at 115. with 342s out back. It also has the 847 cam. with stock suspension. I know the car can run faster but why am i 4-5 mph slower? Yea tq management is a mother of an issue.
Seems to be the common mph guys are trapping on this board with le2 heads no?
hsyr is offline
Old 07-31-2006, 06:34 PM
  #19
Jlo
Jlo's Avatar
The world may never know!! unless Jeff tells us.
Jlo is offline
Old 07-31-2006, 06:40 PM
  #20
redneck01's Avatar
my heads are only 190cc so id be maxing them out prob with the 847, but what i wanna know is how some guys are running 11.8's and others run 11.06? i doubt weight does that much.
Old 07-31-2006, 06:45 PM
  #21
Jlo
Jlo's Avatar
The weight has alot to do with it, the lighter the car the faster it goes. I guess it's all in the combination gears, trans, tunning etc.. etc... I also plan on running a simular set up as jeffs. Mine will be a 383 or a 357 with the LE3 heads and cam which is bigger than the GM847. I just hope to run simular times.
Jlo is offline
Old 07-31-2006, 06:50 PM
  #22
redneck01's Avatar
yea my car is fully gutted with stock k member/a arms, but one seat, etc...i just dont know how fast i can get the thing to go and what tricks will make it faster
Old 07-31-2006, 09:29 PM
  #23
My Iroc Z28's Avatar
Excellent info.. My car is a fat pig and needs a diet i think with that and a 12 bolt i can see 11's in the future, But now I wanna throw some ported Trick flows on and see what this stock bottom end can do with the 847.
My Iroc Z28 is offline
Old 07-31-2006, 09:38 PM
  #24
redneck01's Avatar
you better get some tires on that thing
Old 07-31-2006, 09:54 PM
  #25
Jlo
Jlo's Avatar
I'm going with a tubular K-member with the a-arms BMR claims that with this set up with Qa1 shocks and lighter brake system you can loose up to about 100lbs that's alot of weight. I assume that a standard Z28 weighs about 3500lbs. Remove bumper supports, and all the other stuff not needed and you can weigh in a 3400 to 3300lbs.
Jlo is offline
Old 07-31-2006, 10:26 PM
  #26
brokeTA's Avatar
I thought there was a 355 gm847 car running mid to high 9's on the bottle? I think his screen name is N20t/a maybe?
brokeTA is offline
Old 08-01-2006, 08:32 AM
  #27
WS Sick's Avatar
I guarantee you will gain 3 mph just from going to 3.73s. Also you'd probably gain a tenth or 2 in the 1/4 as well.
3.42s lug the motor too much for this cam.
WS Sick is offline
Old 08-01-2006, 09:56 AM
  #28
Z284thgen's Avatar
Originally Posted by WS Sick
The biggest Obstacle my car has is that my present motor only has about 9.8:1 compression. I know Jeff has closer to 12:1 and his car is lightened.
it was on oct 30 when it did its best
also had 12.43:1 comp and 10.3 DCR flat top pistons
Z284thgen is offline
Old 08-01-2006, 10:00 AM
  #29
Z284thgen's Avatar
Originally Posted by Jlo
Here is one of his vid's on LS1Tech, it's one of my favorites hands down, I just like this car alot looks awsome Great job jeff. What clutch are you using??
http://www.ls1tech.com/forums/showthread.php?t=260288
click on the car pictue on the bottom.
twin disc
car prob weighed close to 3200-3300 with me in it and no roll bar
all BMR front to rear r-series qa1's comp eng rear shocks
Old 08-01-2006, 10:02 AM
  #30
WS Sick's Avatar
Oh Ok, What did you run earlier that year during the summer?
I was thinking you ran a really really low 11 in the heat.
WS Sick is offline
Quick Reply: fastest gm847 cars
