A few Q's
A few Q's
Well it's about that time. After almost a year of waiting im finally putting in my 306. But i have a few questions about the heads and roller rockers so take a look! So far i have...
CC306
Comp 918's
Comp 10 degree Steel retainers
Comp LT1 Sping Locators for 918's
Comp 10 Degree Valve Locks
Comp 11/32 Valve Stem Seals
GM Performance Parts Oil Pump w/White Spring and Late 94 Pickup
Trickflow Chromoly Pushrods 7.200"
95+ vented opti
95 Opti Wire Harness
95 Opti Vac Harness
95 Timing Cover
Cloyes Double Roller
Meziere Electric Water Pump
Others:
New Auburn Posi
Power Transfer Parts 3.73's
TCI SSF 3500
Hayden Trans Cooler
Complete 10bolt Refresh Kit
When i bought my car in November of 2005 it had 20k miles on the fresh 355. They guy told me he had the block resurfaced and a valve job done along with the rebuild. Would you guys think i would have any iston to valve clearance issues with this cam or am i safe?
Also since i dont know anything other than the car has has roller rockers on it from the build i will probably just updrade to Comp magnum 1.6's. Should i buy SA or NSA?
Should i get 7/16 or 3/8 screw in studs?? If i get the NSA RR's what guide plates should i use?
These are the last few things im trying to get sorted out by the first week of December. Thanks in advance guys!
CC306
Comp 918's
95+ vented opti
95 Opti Vac Harness
95 Timing Cover
Others:
New Auburn Posi
TCI SSF 3500
Hayden Trans Cooler
CC306
Comp 918's
95+ vented opti
95 Opti Vac Harness
95 Timing Cover
Others:
New Auburn Posi
TCI SSF 3500
Hayden Trans Cooler
CC306
Comp 918's
95+ vented opti
95 Opti Vac Harness
95 Timing Cover
Others:
New Auburn Posi
TCI SSF 3500
Hayden Trans Cooler
Thanks for the reply. How exactly do i check the clearance? I have never done it before. Thanks for the Rocker info also, i do plan on the ARP studs so i will probably be ordering the last few things here shortly.
