Final word on L67 injectors for LT1
L67 run at 36.5lbs/hr. @ 47-52psi
LT1 run at 24.9lbs/hr. @ 40-45psi?
If I were to acquire a set of 8 running the racetronix 255lph pump and the booster harness, what would I need to tell my tuner the size injector I have?
also do we need to change injector connectors?
Re: Final word on L67 injectors for LT1
You need to give him all the info you posted above re the L67 injectors, plus the manufacturer of the injectors. But injectors are rated at a single pressure, not a range of pressures. Flow varies with the square root of the pressure ratio.
The LT1 injectors are flow rated at 43.5psi.
You might want to just save the injectors for the future, since they aren't needed at this point.
10-31-2016 11:09 AM
ChrisFrez
12-07-2014 06:01 PM
Z284ever
82
08-14-2002 04:06 PM
