Finally got some dyno numbers...might suprised a few people
#18
I wont get a good ET out of my car for a good while, at most im hoping for a 1.8 60' with my stock 10 bolt and im even scared to do that. The mph i ran at darlington was with rocker arms that were way too tight and i had 10 broken harmonic dampeners in my valve springs and 10 busted valve stem seals. I also short shifted the car so there is a good bit left in it, i really need to get the car to the track again and see what i can do with it with the new rockers, new opti, new valve springs, and a bit more compression then i had to begin with. All are whats on the graph other then the new opti which cleaned it up a good bit but i also need a coil.
#20
Yep, stock Throttle Body, hopefully i can get it to the track this thursday with the good weather to see if i can atleast get a good mph, i know the E/T isnt going to be as good as it can be since our track rarely ever preps good. low 8's would be a good day on this track Not to mention this being the first time at the track with;
good tune
good valve train
good ignition system
Should make a big difference since those things are a wee bit important to a car performing well
good tune
good valve train
#27
Im no longer with F-Body Motorsports, the new owners took over and we did not like the direction they were taking the business so we left and started our own place, Zeus Performance. They are not going to do another track day
#28
#29
yea, we're basically the old F-Body, before it turned to **** with a few more improvements. Been together since January, its been a good while since i've made it to the track and i know its the same for everyone else. I was planning on going in the next couple weeks, maybe i'll catch you up there.
whitehooptie
07-12-2015 06:10 PM
