Finally got some pics up of the 383 Stroker! Beautiful!
Old 11-12-2004, 12:42 AM
  #46
Bryan Smith's Avatar
Re: Finally got some pics up of the 383 Stroker! Beautiful!
Originally Posted by Dave88LX
What year? 2003 or 2004? Did you camp?
Even though we're talking on aim. 2004, didnt camp. </*****>
Bryan Smith is offline
Old 11-12-2004, 10:55 AM
  #47
Dave88LX's Avatar
Not a problem, let me know if you need anything else.
Dave88LX is offline
Old 11-12-2004, 12:38 PM
  #48
RedHottG2's Avatar
Looks great Dave!! hope your very happy down the road with it.
RedHottG2 is offline
Old 11-12-2004, 05:01 PM
  #49
Dave88LX's Avatar
Good call on the AC hardlines, these are a PITA to get on!!! Hitting my headers.
I'm going to have to massage things a little I think.
Thanks for the reminder...2 hours and polished AC lines later...here I am.
Dave88LX is offline
Old 11-12-2004, 05:58 PM
  #50
eagleknight97's Avatar
Just out of curiousity, why did you put the Delteq on the valve covers? Personally, I would put it down by the radiator. I just think that putting them on the valve covers just add more clutter to the engine bay, especially on top of the valve covers.
eagleknight97 is offline
Old 11-12-2004, 06:55 PM
  #51
unTAmedLS1's Avatar
Hey I gotta 383 that looks just like that Ill get more pics up soon
Motor
unTAmedLS1 is offline
Old 11-12-2004, 07:20 PM
  #52
Dave88LX's Avatar
Personal preference I guess...I paid like $500 for the damn thing, I wanted it to be seen.
Dave88LX is offline
Old 11-12-2004, 07:37 PM
  #53
Dave88LX's Avatar
Yeah...so...you made me polish the damn AC lines.
http://paradox.shacknet.nu/dave88lx/...l/AClines1.jpg
http://paradox.shacknet.nu/dave88lx/...l/AClines2.jpg
Dave88LX is offline
Old 11-12-2004, 08:07 PM
  #54
IrocSS85's Avatar
just take the butt end of the hammer and push down on the line to give ya about 3/4-1" clearance between the header pipe and the a/c pipe. what is your procedure on polishing the lines? whatever it is it worked really good. do you have a polishing wheel or what?
IrocSS85 is offline
Old 11-13-2004, 11:04 AM
  #55
Dave88LX's Avatar
I used some of Turtle Wax's Polishing Compound on a rag (green container) then followed up with some "Blue Magic".
Now I gotta do the other line.
Yah I had to unbolt the AC compressor, slide it forward, hook up the lines, then slide it back, and bend the lines slightly forward still. Grrr.
Dave88LX is offline
Old 11-23-2004, 09:58 AM
  #56
AlmostfastLT1's Avatar
Hey, I was wondering I am ordering these bushings and as far as the trans mount goes, I have a manual and I was wondering is it universal. Just making sure it will fit on my 6speed for a 94. Also, I am running the bmr k member and not too sure which motor mounts to get, not wanting to go to solid, but I assume I still use the factor mounts and insert poly?
thanks Mark.
Thanks! Yeah it's not too bad here, supposed to get down to 36* tonight though!
It's not the LTCC, but Delteq. It still uses the Optispark, but only for reference of crank (cam? whatever) position for timing. That signal is sent to an ignition module that's sitting under the coil packs on the valve cover.
Thank you! What I did was glass bead it first, then I hit it up with a wire brush on a drill, really brought out the shine!
I got the bushings from Thunder Racing, Prothane brand. See if this link works:
http://www.thunderracing.com/catalog...&vid=4&pcid=92
47-19-409 Prothane Polyurethane Front Swaybar Endlink Kit , 93-02 F-body $13.99
47-7-1136 Prothane Polyurethane Front SwayBar Bushings, 30mm, 93-02 F-body $12.99
47-7-1604 Prothane Polyurethane Transmission Mount, 67-02 F-body $22.99
47-7-1609 Prothane Polyurethane Torque Arm Bushing, 82-02 F-body $14.99
47-7-227 Prothane Polyurethane Front Control Arm Bushings, 93-02 F-body $29.99
I got the motor mount from Auto Zone, Energy Suspension I think it was, for around $25 if I remember right.
Thanks for the comments guys!
AlmostfastLT1 is offline
Old 11-24-2004, 01:10 PM
  #57
ttt
Old 03-07-2005, 05:33 AM
  #58
Dave88LX's Avatar
Hey Mark, correct (Even though I'm probably too late now). Your drivers side upper motor mount (clamshell) is rebuilt with poly inside and it comes with new bolts to bolt the thing back togother. The passenger side on the BMR already comes with a poly or rubber in it, and you bolt your passenger side solid upper to that. I wanted to go solid on the drivers side, but I couldn't find what I was looking for.
The tranny mount should be universal, but mine is a 6-spd as well so it should work just fine for yours.
I have so many damn pics, I really need to build a webpage for them all.
Here are some more recent pics with the new 5.1 Mpixel cam.
http://paradox.shacknet.nu/dave88lx/...ll/cradle5.jpg
Yes, definitely need to clean up the accessories.
http://paradox.shacknet.nu/dave88lx/...ll/cradle8.jpg
http://paradox.shacknet.nu/dave88lx/...l/install7.jpg
Dave88LX is offline
Old 03-07-2005, 10:13 AM
  #59
SS MPSTR's Avatar
Dave,
What is the dealio with your engine now?
SS MPSTR is offline
Old 05-20-2011, 08:50 PM
  #60
Dave88LX's Avatar
Originally Posted by shoebox
The longest rebuild in history finally begins the home stretch!
Looking through some old threads. Damn Rob. I like how in 2004 you called it the longest rebuild in history.
Too bad my old hosting is down.
Dave88LX is offline
10-31-2016 11:09 AM
D1SC383LT4
01-01-2016 01:56 PM
Rde Bandit
03-21-2015 10:17 PM
maybe2fast
03-13-2015 11:48 AM
D1SC383LT4
01-26-2015 01:41 PM
Quick Reply: Finally got some pics up of the 383 Stroker! Beautiful!
