Finally...track times
Old 10-31-2007, 02:09 PM
  #76
Colin91Z's Avatar
Houston....we may have a problem
I was driving it on my lunch break, and I rolled into the throttle in 1st....and it started poping pretty loud out of the exhaust. Of course, I let out of it....then tried it again to see what RPM this was occuring at, it was at 5800...
I don't even wanna say what I think it sounds like....but I will say that I'll be driving it home very gently and pulling the valve covers tonight to give my 918s a close inspection.......
This may put a damper on my Sunday
Colin91Z is offline
Old 10-31-2007, 03:15 PM
  #77
SStrokerAce's Avatar
Could have easly loosened up a poly lock on the rockers.... if the spring went you wouldn't be driving it any farther down the street!
918's < 1218's!
SStrokerAce is offline
Old 10-31-2007, 03:21 PM
  #78
Colin91Z's Avatar
It's not making any abnormal valvetrain noise at idle or anything....just the loud popping at ~5800ish....kinda sounds like it's valve floating very badly
Who knows, I'll yank the valve covers tonight and report what I find. I guess if the valvetrain looks ok, I should probably look at the ignition?
If the springs ARE bad though....they'll be replaced with PACs. If thats the case, hopefully Comp will give me a refund rather than a new set of springs.
Colin91Z is offline
Old 10-31-2007, 03:55 PM
  #79
SS MPSTR's Avatar
918's < 1218's!
so the other 7 cylinders notice that the spring on one is broken? it will drive, but can exhibit the exact same symptoms as described.
does this cam have the 3192 and/or 3122 lobes too? cast core too?
SS MPSTR is offline
Old 10-31-2007, 03:58 PM
  #80
Colin91Z's Avatar
I dunno what lobes, but it is a cast core....
Colin91Z is offline
Old 10-31-2007, 04:21 PM
  #81
87bandit's Avatar
sounds like a high rpm missfire
check plugs and wires
mine did the same thing after my cam swap, would break up after 5,000rpm ended up being wires
87bandit is offline
Old 10-31-2007, 04:43 PM
  #82
Colin91Z's Avatar
Ok, I'll check but the wires and everything are brand new, and it ran fine...it just started doing this today.....I might pull all the plugs and see what they look like...
Colin91Z is offline
Old 10-31-2007, 04:48 PM
  #83
87bandit's Avatar
could've melted a wire on a header primary and it's arching now
87bandit is offline
Old 10-31-2007, 04:55 PM
  #84
Colin91Z's Avatar
Ahh good call, I'll be sure to look for that too
Colin91Z is offline
Old 10-31-2007, 05:26 PM
  #85
Easy now chicken little, believe me if you break a spring off that valve and piston will talk to one another about 10 times a second so your going to get a lot of check engine lights coming on extremely fast!
Then again you would have to be around motors not drafting boards and CAD programs all day to know what happens in the real world.
Bret
Old 10-31-2007, 05:28 PM
  #86
Colin,
The only thing that semi worries me is that they are Comp 918's not PAC ones. The only reason is that I have only had issues and bent springs out of the new Comp versions, where none with the PAC's on a hyd roller application.
If you broke a spring it would make a HUGE racket. The wires and rockers would be the first things I would check. Especially if all you have is a problem at a high RPM not all the time.
Bret
Old 10-31-2007, 06:29 PM
  #87
speed_demon24's Avatar
There are dozens of people that had broken 918's and they didnt realize it since just the top coil broke off. The retainer was just sitting on the coil below it.
speed_demon24 is offline
Old 10-31-2007, 06:49 PM
  #88
Yeah, I undstand that I have some of those 918's from the other supplier and they are at PAC for them to look over and see the cause of the failure. Most times that's where they broke is the top coil. Either way you most likely drop a valve.... odd thing is that this doesn't happen on PAC's 1218's... hmmmm.
I'm glad your the expert on them now though... funny that your beehives didn't break from the cam I gave ya.
Bret
Old 10-31-2007, 07:00 PM
  #89
SS RRR's Avatar
Originally Posted by Colin91Z
It ****feels**** fastest shifting @ 6700 (of cousre a butt-o-meter is not always reliable)
Enter your power curve into a shift point calculator to give you some baseline figures for your next trip to the track. This, of course is if you get your problem figured out.
SS RRR is offline
Old 10-31-2007, 07:28 PM
  #90
Bret
I never said I was an expert, and they were down 30 lbs on the seat after 4000 miles.
Quick Reply: Finally...track times
