Finally...track times
#121
i had a similar situation when my motor was installed,they moved my fuse box and they seemed to have pinched the PINK wire on the metal tray and as i was driving i hit a bump
and it finally grounded then KAAABOOOM!!!!!!would not start again so i did some searching and that is what i found! eventhough the problem was the short i still replaced the opti the crank position sensor and the icm
#122
I'm gonna go check for pinched wires, BRB
#123
I think its fixed
I couldn't see any wires pinched from the top, so I just unsnapped the fuse box from it's base and looked under it. It appeared that a couple of wires (one of them being pink, what are the odds?) had been pinched so I re-positioned everything, and snapped it back down. Confident that none of them are pinched any longer I figured "what the heck" and put a 10amp fuse in and cranked the car over....well now I have spark and the fuse didn't blow!
#124
I think its fixed
#125
I got it all put back together yesterday morning and headed for the track...I got there, teched in, made one pass.....
Shifted @ 6700 rpm on this pass by the way....
I know that pic is hard to read so here's what it said:
60'----1.89
1/8----8.01@90.95mph
1/4----12.32@115.86
The launch wasn't very good (it spun pretty bad coming out of the hole, and spun in 2nd a little too) so I was confident that if I let it cool for a while and lowered my tire pressure a few psi, and did a longer burnout that I could better the first pass by a couple of tenths for sure
...and then when I went to make my second pass it wouldn't start
Now I have a no crank, no start situation. I even tried push starting it, it would fire that way for about 1 second and then die again like something killed the ignition.
I was so pissed last night when I got it home that I didn't even bother trying to find the problem. I guess I'll take a look tonight and see what I can find
I guess there's always next sunday.....
60'----1.89
1/4----12.32@115.86
#127
This is a totally different problem than I was having previously, before it would crank but had no spark...and now it won't even crank. I'm suspecting a VATS problem seeing how it has killed the ignition system too (won't allow it to be push started)
#129
I've been using the search funtion though, and I'm pretty sure that I had Bryan @ pcmforless diable the VATS in my PCM, I'm waiting on a email back from him to confirm this. If so, then if I were to permantly ground the yellow and black wire that goes to the TDR...It should start.
#130
How long was the car down before the new motor? Did you have to jump the battery when you got it running for first time? I had a battery that hadnt been used for like 8 months, when I went to start the car I had to jump it... slowly lost charge after that. Probably lasted another few weeks/months, but what does the voltmeter say in the car?
Sounds like the starter is doing the work, but no spark or fuel? Sounds like it might be back to the spark issue.. just later in the chain? By adding a larger amp fuse, you may have shorted something out. I would check what else is run through that fuse you where having problems with and see what else is run through it. Once you find out what is running through it, try and see that they are all getting enough voltage (especially the starter if this is run through same wire).
Good times to see! I am running 12.5s@110 out here, so there is an 11 in it I would almost guarantee! Goodluck, I will keep reading and hoping I can help... glad to see another LE car running good
#131
Oh...I wouldn't classify my car as an LE car...Lloyd ported my intake...but Chris Bernd at Cylinder Head Specialties in Wellington, KS gets the credit for the heads
Thanks again for all the suggestions, and stay tuned cause I'll be going back to the track this sunday to try again
#132
After mucho use of the "search" function, I determined that I must have a bad ignition lock cylinder causing my no crank, no start situation. Aparently it's pretty common for the little wires from the lock cylinder for the VATS to break. When they do, it causes the exact syptoms that my car had. Sure enough, I pulled my column apart and found that one of the wires had broken in two. So I replaced my lock cylinder and key tonight, and she fired right up!
Assuming nothing else goes wrong...I'll once again be headed to the track this Sunday to try for 11's
#135
Well you learn something every day. I did not know it was "common" for the wires to break. Anyway good info! Good luck on your hunt for the 11's N/A. I wish I was at that level. Come spring I hope to be there.
